Re: Re: Re: Re: Farmall H value
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Wardner-Correction on April 07, 2000 at 12:16:16 from (63.23.216.68):
In Reply to: Re: Re: Re: Farmall H value posted by Wardner on April 07, 2000 at 12:03:05:
Forget about that neutral stuff. The diferential will spin at 2x its normal speed for the gear that the transmission is in. If the tractor was only used for PTO work, the diferential should be OK. Sorry bout that.
Post A Followup
: Re: Re: Re: Re: Re: Farmall H value
