Posted by bc on February 24, 2009 at 07:45:21 from (68.88.175.43):
In Reply to: 1486 steering posted by Hugh MacKay on February 23, 2009 at 07:48:55:
Don Anderson said: (quoted from post at 10:48:55 02/23/09) The steering on my 1486 is becoming a worry driving on the road. The front tires get to wobbling back and forth in unison. I am wondering if it has something to do with the seals in the steering cylinder since the pitmans and ball joints appear to be tight. It is hard to tell driving down the road. My main concern is that something will break driving down the road and I will end up someplace that I do not want to be. Even turning on rough ground in the field there appears to be a lot of slop but at least if something would break there I am going slow enough to avert disaster. Thanks for any suggestions.
I had that wobbling on my 2606 going over rough ground. Raised the front end up and found the 3 bolts in the bottom holding the trunion in were loose. Tightening helped some. Since I was having steering problems anyway and I could see the rod in the steering cylinder moving back and forth with the wheels, I rebuilt the steering cylinder. That stopped the wobbling. When I bought the steering cylinder kit, the parts guy talked me into buying new bushings for the trunion pins. When I got it apart, the original bushings fit tight on both the pin and in the housing. Left the old ones in there. If the rod in the steering cylinder wobbles back and forth also, then that is where I'd start. Hydraulic psi should hold it solid. If it doesn't move, I'd look somewhere else. If those trunion bolts are loose, you may want to use loctite. Let us know what you find out.
Today's Featured Article - Bad Vibes - by Curtis Von Fange. One of the strangest ways to communicate with our tractor is to ask it how it feels. "Ask it how it feels," you say? Yup, ask it how it feels. Now, as with the other articles in this series one has to be able to hear what 'ole blue' is trying to say in response. The nice thing about our old iron friends is that they are usually quite consistent in their response, rather unlike some people I know who might change what they say due to the weather or other mitigating circumstances. But since t
... [Read Article]
Latest Ad:
[More Ads]
