Posted by eric skokan on February 24, 2009 at 10:50:10 from (71.212.136.110):
I"ve had some great help from some on the board but I need a little more. I"ve set the timing using the rough method. Then I found the timing mark on the flywheel and lined it up with the pointer. I set the rotor to fire #1. Buttoned it up but still no spark at the plug. I then pulled the mag lead and set it next to the mag body and turned it over. Still no spark off of the mag lead. Then I pulled the ground wire off of the mag and tried it again. Still no spark.
So, first I"m curious if I"ve done these tests right? Second, if I"ve done it right, what do I look at next. I checked the points and they are at .13 and while they aren"t new they don"t look too bad. Any thoughts?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
