Posted by Hugh MacKay on February 24, 2009 at 12:05:24 from (209.226.247.78):
In Reply to: Re: Super A Numbers posted by JerryB4 on February 24, 2009 at 10:22:58:
Jerry: All you need do is remove the bottom coolant port to the block. The pump bolts in same place using same holes. You will need a longer bolts and a longer fan main fan belt as with water pump, belt goes around 3 pulleys instead of 2. If you ask for a 100 or 130 fan belt, it should work.
I can't tell you proper length for those bolts, I've never had my SA and 130 apart at same time. Best to do a measure of pump and block hole depth.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
