Posted by Hugh MacKay on February 24, 2009 at 16:28:16 from (64.228.11.175):
In Reply to: Re: Super A Numbers posted by Hugh MacKay on February 24, 2009 at 12:05:24:
Jerry: No, you can't use a radiator from a Super A1, 100 or 130. That readiator is two inches higher and your sheet metal will not fit.
Your best bet is go for a recore at a local radiator shop. Find a shop that does a lot of tractor radiators. Make him aware that you are changing it from thermosyphon to water pump. The cores are different for the two systems. It will cost you close to $400. Don't try to cut corners.
Tractorsam ran into this couple years back. His dad decided to get the radiator recored while he was away. Turns out the shop installed a core for a water pump. Sam couldn't get it to work on thermosyphon. In the end he had to go water pump.
A lot of folks have done these without a thermostat. Personally I think an inlne thermostat in the upper rad hose, similar to type used in 100 or 130. My 130 has an inline thermostat with a hole in it to allow bypass,
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
