Posted by Janicholson on February 25, 2009 at 07:44:17 from (199.17.6.128):
In Reply to: 300 u fast hitch posted by farmall dave on February 25, 2009 at 04:50:43:
The priority valve might be diverting the fluid to the PS, and when cold, it has enough pressure/flow for both. when warmed up it may bypass enough fluid at the pump to reduce the amount/pressure to the hitch. Flow rating the pump will pinpoint this for sure, but it is pretty certain if it is a oil temp issue. Unless the tractor has non hytran spec oil in the system. IH or JD oil meets spec, as do many other oils. But an oil that thins down excessively will exagerate the weak pump. The steering system, for safety, will always get first billing on the hydro list. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
