Re: 300 u fast hitch
Posted by Dellbertt on February 25, 2009 at 17:14:55 from (209.172.22.242):
In Reply to: 300 u fast hitch posted by farmall dave on February 25, 2009 at 04:50:43:
Dave,
I had a sticky controller once on my Case and wiggling the lever and tapping LIGHTLY would free it up.
Use JimN thoughts and do some trouble shooting.
Does it happen cold as well has hot.
What fluid type and level.
Stock hyd pump?
Does rear lift work better in single or double action.
No leaks?
Tap LIGHTLY on controllers, safety and priority valves.
Did you check the hyd screen under the seat in the reservoir (this is a last ditch effort as pulling the reservoir top is a PAIN.)
Pump Noisy?
Does PS shake?
Dell
