Re: Workin' on a dream (460 utility)
Posted by IH fan on February 26, 2009 at 05:11:21 from (70.250.252.142):
In Reply to: Workin' on a dream (460 utility) posted by marklowery on February 25, 2009 at 19:12:26:
Do you have a picture of the 3 point? Reason I ask is the only 460U I've ever seen with a 3 point was the experimental model that the company I worked for developed in the early '60s with IH. It was never put into production at that time, but IH later "developed" their own that had many of the features. I worked on it a little in late '65/early '66 when the tractor was sent to Oliver for evaluation. During testing, I pulled a 4x16" Oliver semi-mount in the field... never would have believed it could pull one that big.
I'm guessing this one has the external cylinders like the Fast Hitch?
Looks like this one will make a great project.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
