Posted by joe 1971 on February 26, 2009 at 16:16:35 from (216.51.206.86):
I got a 1456 that i thought the clutch was bad so i replaced it. turned the flywheel with new disc and pressure plate. i got the clutch adjusted properly. this is not my tractor. well when i got done i started it up and thought id try to make sure it hooks up. i put it in any gear and hold the brakes it only pulls the engine down just a little and my foot is off the clutch pedal. im thinking that it was not clutch issues at all now. i took a pressure test at the bottom of the mcv valve and reads 300lbs when the torque is ahead and back. the tractor slipps whether the ta is ahead or back. i also had adjusted the torque along with the clutch. i talked to the owner and he said that the tractor free rolls down hill with a load behind it. i had every valve out of the mcv valve and the all move easily and no scoring. What else can i try? do you think the torque could just go out that fast? I did make double sure that I do have free travel at the clutch pedal. The tractor acts the same way as it did before i put the new clutch in it. isnt it unusual for the high and low side of the torque to go bad at the same time? im just wondering if i got something other than the torque that bad. Thanks for any help you guys can give me. Joe
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
