Re: 1456 slippage
Posted by Owen Aaland on February 26, 2009 at 19:04:04 from (65.165.246.54):
In Reply to: 1456 slippage posted by joe 1971 on February 26, 2009 at 16:16:35:
When the flywheel was resurfaced was the PPA mounting surface also machined to the correct distance to the friction surface? Pressure Plate Assemblies are usually shipped with spacers under the levers. Did they get removed?
It is unusual for the TA to fail on both sides at the same time. Does the pressure drop off as you shift between high and low? Does it drop off when the clutch is released and the dump valve is pulled open? When the MCV was reinstalled, did you happen to use a gasket for a non TA equipped tractor?
