Re: Workin' on a dream (460 utility)
Posted by mattofvinings on February 26, 2009 at 16:49:35 from (67.142.161.29):
In Reply to: Workin' on a dream (460 utility) posted by mattofvinings on February 25, 2009 at 19:12:26:
Here are a few more shots...the Binder manuals also arrived today! :D
third party image
third party image
third party image
I took off the carb this afternoon, split the halves, and dumped all of the nasty stuff out. Got some fresh gasoline and let a little flow...also some nasty stuff out of that. Then I had clear gas and got the tractor running smoothly on about 1/4 choke. It still isn't 100% right, but good enough for me to drive it around a little bit. Throttle and choke cables are still not working smoothly. I pitted it against the sod in once place and tore out a nice chunk...perfect!
This was formerly in the photo ads...you snooze, you lose 8)
This post was edited by mattofvinings at 16:50:37 02/26/09.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
