Re: farmall h field resistor
Posted by ScottyHOMEy on February 28, 2009 at 07:17:23 from (70.105.240.166):
In Reply to: farmall h field resistor posted by Jay SD on February 28, 2009 at 07:08:06:
As a last shot on your existing resistor, did you check the continuity between the rivets. If ound continuity on the eire but not on the rivets on mine and fxed it with a couple dabs of solder.
You can also replace it with an off-the-shelf resistor from Radio shack. Not sure how it's rated, but I think maybe JimN or BobM posted it a few times. It'll be tedious, but if you can search the archives and find it . . . or maybe one of them will see this and jump in.
I've had poor results with the replacement switches.
