farmall h field resistor
Posted by Jay SD on February 28, 2009 at 07:08:06 from (69.77.240.24):
According to the testing I have done, it says I have a bad field resistor on my 4 position light switch. I grounded the f terminal on the generator to the positive ground and it charges. This is still 6 volt. The local dealer does not carry a resistor but has a new switch. The new switch doesn"t have a resistor. Is it built in the new switch? Will another type of resistor work? I checked it with an ohmeter and it tests good for wire not being broke anyway. If I jump this it will damage something else, any suggestions?
