Re: 1086 Acceptable Engine blow by
Posted by bemhoff on February 28, 2009 at 07:50:36 from (208.19.154.2):
In Reply to: Re: 1086 Acceptable Engine blow by posted by Allan In NE on February 28, 2009 at 07:28:54:
Alan, thanks for the reply. I agree they will have blow by when new. What i am lookiing for I guess is the amount of blowby when new. As the compression decreases the blowby will increase and you can measure that which is what I did. This should tell you how much compression is being lost past the rings. This is how semi truck engines are gauged as for when they are at the rebuild point. It may be that the AG industry never got this technical or detailed.
Thanks again, Bemhoff
