Your tests are all good but do you have ground from the sw to ground. Use your meter to see if the sw body is grounded as it has to be grounded for the system to work as thats probably your problem. With the engine running you can place a jumper from sw to the pos ground at the battery and see if that makes it charge.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
