I agree with JimN below. Problem may be a bad ground at the ammeter box. (For the generator to work the LHDB switch must be SOLIDLY grounded to the tractor frame.)
On a more practical matter if the problem turns out to be a bad switch/resistor, I highly recommend replacing the original cutout relay for a voltage regulator. Your battery will be maintained better and will enjoy a longer life. The LHDB switch then becomes simply a light switch with two "off" positions.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
