Re: farmall h field resistor
Posted by pete 23 on February 28, 2009 at 10:37:12 from (173.87.1.12):
In Reply to: farmall h field resistor posted by Jay SD on February 28, 2009 at 07:08:06:
You may well want to put on a voltage regulator as suggested. If you prefer to stay with the high low charge, I would run a ground wire right from the light switch back to the generator. Eleminates all poor grounding of switch to cover, cover to box, box to steering post, steering post to transmission. Hook wire to grounded end of resistor.
