Just looked up the specs, the orfice size is .406 for that series of engines and .277 on the german diesels. It does show 5.5 inches of water as max. I have checked many over the years and they do vary quite a bit even on engines that are performing well but it is still a very good indicator of wear. The DT 414 started using the pressure balanced pistons and larger breather at engine sn 118713. A lot of engines overhauled over the years have that piston and ring installed, not every one installed the breather kit however. If they didn't there was a lot of oil carry over out of side mounted breather. Food for thought.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
