Re: 1086 Acceptable Engine blow by
Posted by bemhoff on February 28, 2009 at 18:22:57 from (98.21.20.106):
In Reply to: Re: 1086 Acceptable Engine blow by posted by pete 23 on February 28, 2009 at 16:05:14:
Pete, thanks for the info. Sorry for the delayed reply. I was at work all day and was popping in and out of the office to check my post. The local IH dealer suggested about the pump. That would be easier done than a engine kit. I can check the orfice size on the blowby tester next week. It builds about 60 psi oil pressure when it is first started, and after working it for a while it drops to 15 at idle. The way I have been starting it when it's real cold out is with ether but I moved the line from the intake to the air cleaner canister, it doesn't seem near as hard on it but you go through a little more ether. Thanks again for your time and efforts. Bemhoff
