Re: Super A Died
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by maballance on April 07, 2000 at 18:31:43 from (209.244.214.204):
In Reply to: Super A Died posted by Ralph on April 07, 2000 at 16:38:43:
Same thing happened to mine, it was a short in the hot wire to the coil. Hope that helps some what. There's some pretty sharp folks on this board, you should be able to take care of it with one of them's help.
Post A Followup
: Re: Re: Super A Died
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
