Re: Farmall H Problems
Posted by Farmall Bob on March 01, 2009 at 17:23:07 from (24.31.158.92):
In Reply to: Farmall H Problems posted by tgrewing on March 01, 2009 at 17:07:40:
Hi Tgrewing,
The points have to be set at a certain gap when open. You have to crank the engine around to make sure this is done properly. Also they want to set nicely together when they are closed. If this seems correct, may be there is something else wrong like the shaft and bushing to the distributor is worn badly. This will cause you problems to no end. Does it have play in it? Hope this helps.
Bob
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
