Using lock nuts on connecting rods
Posted by Red460 on March 02, 2009 at 07:04:41 from (75.187.204.54):
I am volunteering at a railroad historical soc. to overhaul a 200 hp gas engine (1941 vintage) in an industrial switcher. Access to the connecting rods is through hand holes down between the frame. I cant see the rod caps I have to do everything by feel.
Q: Can I use nylon lock nuts on the rods to connect the rod caps.
