Re: Using lock nuts on connecting rods
Posted by mattofvinings on March 02, 2009 at 14:35:10 from (67.142.161.34):
In Reply to: Using lock nuts on connecting rods posted by Red460 on March 02, 2009 at 07:04:41:
Adding to above: I would not trust the nylon locking insert to hold up thru the heat inside an IC engine....
