I mentioned it in my answer to your question about the rear wheel over on Tractor Talk, and it's even more imprtant on a front wheel, with it being smaller - - -
If you're going to cut that weld or put any kind of serious heat to it, let the air out of the tire and remove the valve core from the stem. You might even try to break the bead before starting, too.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
