Re: 1941 H Magneto timing questions
Posted by Farmboy856 on March 02, 2009 at 20:10:44 from (72.49.233.166):
In Reply to: 1941 H Magneto timing questions posted by ldreyno on March 02, 2009 at 17:48:43:
Janicholson has it right. I recently ran into a similar situation on an A. PO had "converted" mag to an external coil and fed the points through the kill switch terminal on the side of the mag. A helper mistakenly took the rotor gear out trying to get to the points to file/clean them. I could not make either of the marks--- the "L" or the "R"--- get the rotor button anywhere near the #1 plug wire position when the #1 piston was at TDC on the compression stroke. Being the tinkerer that I am, I finally set the gear so the rotor button aimed at #1 plug wire hole (approximately 2:00 o'clock position) when the #1 piston was at TDC on the compression stroke. Set at this, the impulse clicked, and she fired right up.
