Re: Need help takin' radiator off H
Posted by DuaneH on March 03, 2009 at 18:01:17 from (70.105.71.20):
In Reply to: Re: Need help takin' radiator off H posted by Haas on March 03, 2009 at 17:46:49:
Thank you very much for the info..... I was lucky on the two bottom bolts, I got them off. Now I have gotten the steering shaft off, but I cant get the radiator far enough forward to get it to slide it out the side. Steering tower in front...fan in the back. The shroud is loose with the bolts out.... but THAT is the problem. The shroud wont clear the fan and I cant take the radiator to the side because I cant get the shroud unattached even though its loose. ???
