Re: Distributor question on SC
Posted by Janicholson on March 04, 2009 at 15:52:04 from (66.173.50.147):
In Reply to: Distributor question on SC posted by DRC on March 04, 2009 at 13:18:56:
If the wire you are using to "hot wire it" is sound, and your certain of the connection integrity there, I suspect the points are shorting out to the distributor plate. The tiny nut holding the spring, ans the condenser lead can bengd the spring against the plate, This might just require a re install of the points. JimN
