Distributor question on SC
Posted by DRC on March 04, 2009 at 13:18:56 from (24.123.254.253):
I'm having an intermittent spark problem on my SC. This is a newly re-built engint that I'm test running with a jumper wire from the battery. I have great spark, and then nothing. I used the original dist. insulator, but that looks fine. Swapped condensors, etc. I put a film of grease on the distributor where it slides into the drive housing. Maybe that's effecting the ground? Also, when I snap the points by hand, I could swear the spark is arcing down to the ignition plate. My eyes aren't what they used to be, but it sure looks to be arcing. Any reason for that?
Thanks, Doug
