Might not be the same problem, but I had to clean the rust etc. from the outside of the coil lead on the distributor. However you say your spark is intermedient. Sounds like a bad connection or a bad wire. Why are you hotwiring? Since these tractors are positive ground, did you bring your power from the positive side of the battery or the negative? If you came from the positive side and the rest of the wiring is proper, switching the tractor on could cause a direct short.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
