Posted by tipper on March 06, 2009 at 18:40:22 from (75.88.240.252):
So what valves misbehaving can lead to the PTO being on all the time? If the PTO is staying on (and the MCV plate gasket is known to be good), what must be open and allowing pressure to get to the PTO port? I can disconnect the linkage completely and the PTO stays engaged. I have removed the pto valve from the MCV, and I did not notice any problems. I'm not saying there isn't a problem, but the valve moved freely. I am contemplating hooking a gauge up to see exactly what kind of pressure I have while it is "off" and still turning. As I said before, you can hear something different going on when the PTO is officially engaged--this would lead me to believe that the pto valve is opening more (and it is not a straight and full flow leak), but can a leak on that valve in the closed position cause this? Are there any remedies for a valve that leaks--I only see two o-rings in the breakdown, and I doubt either are in "keep the pto from turning" places.
BTW, I'd assume a stuck flow divider valve would keep something from working--not keep something from turning off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
