Posted by Owen Aaland on March 06, 2009 at 23:26:31 from (65.165.246.54):
In Reply to: SMTA rear end posted by Mike Schwartz on March 06, 2009 at 21:44:15:
If you do not have any leakage into the brakes the most likely place for the bearing pieces to come from is an inner axle bearing. If you have a quite place to work on it you can usually hear the the problem by jacking up a rear wheel. Slowly turn the wheel and listen for the balls to drop as the go over the top of the inner race. With the separater missing the balls will all be together in a row. As you turn the axle they will roll up one side and then fall down the other side. You might also be able to hear a rumble as the axles and bull pinions are turned.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
