Re: Need help with MD fuel problems
Posted by D Slater on April 13, 2009 at 18:54:52 from (71.164.37.156):
In Reply to: Re: Need help with MD fuel problems posted by Roger46 on April 13, 2009 at 17:21:16:
If it has a water trap with a water bleed valve it also has a air bleed screw. The head of screw is pointed toward front of engine. Some early water traps didn't have a water drain valve.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
