Re: Need help with MD fuel problems
Posted by Roger46 on April 13, 2009 at 17:21:16 from (70.215.34.171):
In Reply to: Need help with MD fuel problems posted by BruceS. on April 12, 2009 at 17:07:24:
Bruce,
The valve on top of the glass water trap actually is for draining off the water in the bottom of the glass bowl (there is a tube that runs to the bottom of the bowl). In order to get the air out of the glass bowl, you need to leave the nut on the bottom of the bowl loose until the bowl fills, and then tighten it up when fuel comes out around the gasket (similar to getting air out of gasoline sediment bowls). As Geoff said, the engine will not run right unless you purge the air out. Anytime you open up the fuel system which includes changing filters, fixing lines, etc. you need to purge out the air. The manual has a procedure for bleeding all the air out. Roger
