6 volt generator problem?
Posted by Gordy from Iowa on April 13, 2009 at 19:39:04 from (64.12.116.73):
I don't know if the generator on my super m is charging or not. But, with the engine off and the lights turned on, the amp meter goes to the charge side instead of the negative side. Would like to fix that first and then check out the generator. I have the battery positive grounded as the manual says. Thanks for any suggestions!!
