Re: 6 volt generator problem?
Posted by Bob M on April 14, 2009 at 04:43:42 from (151.190.254.108):
In Reply to: 6 volt generator problem? posted by Gordy from Iowa on April 13, 2009 at 19:39:04:
Gordy - You need to swap the wires on the ammeter terminals in order to make it read correctly. (For safety temporarily disconnect the grounded battery cable while swapping the wires!)
Punch below for a flow chart that should help isolate the problem if the generator is not charging.
