Dave,To start with your paw should not have to be reset unless the motor tries to start{a higher rpm than cranking}.Next your choke must work and all the linkage from the air breather must be fitted tight,becaues your moving gas quite aways.Third your float is critical in the carb,And fourth you need to play a little with your timing to find a sweet spot where it will start easy and run smooth when your timming lever is in the down position,these old tractors are a pain in the butt,but when its right it will start the first crank or two
