Re: McCormick-Deering 10-20 runs but I can't hand crank s...
Posted by Dave Koenigsfeld on April 18, 2009 at 06:49:44 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 runs but I can't hand crank s... posted by James Williams on April 17, 2009 at 18:30:06:
what if my pawl kinda bounces up after the first crank and doesn't fully engage the next notch? Can Does it only need to catch the impulse once? My motor guy held it down for us while we crank started it that first day.
My choke is good but I'm not exactly sure if the float is working right. Since the motor fired and ran for a few seconds with an empty carb and the fuel line not hooked up, I guess I was just trying to isolate that my timing wasn't set right or my priming wasn't correct to even get a pop or partial fire while cranking. Fuel while running seems to be fine.
The motor guy timed the tractor and we drove it around. He made one slight change that I didn't see but he made an adjustment on the timimg rod so that we could ground the mag to kill the motor. After that change we couldn't had crank the motor that day BUT we didn't try much since we were chasing a clutch problem.
I will try less fuel, check the color/amount of spark and try again.
thanks,
dave
