Bat terminal on ignition switch should go to alternator side of the amp meter. The wires to coil/resistor and #1 on alternator should connect to IGNition terminal on the switch.
You say the battery is not charging, but the amp meter pegs full to the charging side.
How is your battery connected? With alternator it should be negative ground.
If it is connected positive ground it will "let the smoke out of the alternator" and the system could be going full discharge but the ammeter is connected backwards for the now positive ground battery so it shows full charge.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
