Posted by TimChandler / S-OK on April 18, 2009 at 18:43:02 from (70.254.243.134):
I"ve been trying to get the power steering to work proper on our 400. So far I"ve put a new aux priority valve check ball spring(no change) Pressure is 0 on 2000 # gauge out of pressure port until ya pull a hyd lever, then goes to 1100 # got another priority valve, same results - 0 on 2000 # gauge until a lever is pulled then 1100#. Read all archives on power steering. Came to post about a plug used in power steering tractors to block oil passage to valves. Off come hydro valves. Yup there"s a plug in bottom most passage of the first valve but it"s loose and has no O ring. Mine is 1/2" long x 1/2" dia with a groove in on end and an odd 1/4" tip that"s misshaped on the other end. Can"t find this plug in online parts manual or the O ring. Is it suppose to be in the manifold or the valve? Mine has an odd tip on one end that looks battered. What holds this plug where its suppose to be? Mine can go in the manifold and pass all the way through the first valve. I assume this isn"t right. This thing is about to become a non power steering tractor cause it"s making my head hurt. Sorry for the long post just trying to keep it as close to original as I can afford. Thanks for the help. Tim from the Rocking TJC
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
