Posted by SDE on April 19, 2009 at 07:08:45 from (75.121.171.182):
In Reply to: 300 wont fire posted by makin'hay on April 18, 2009 at 12:28:00:
Maybe I was just lucky, but here is how I did mine. Put the #1 piston to TDC, then with the dist. cap off, rotate the distributor slowly until a spark arches accrossed the points. Put the cap and wires back on and give it another try.
Clutch. Does the spring return the pedal to the deck? Do you have about 7/8 inch freeplay when you push in the pedal? If the clutch was replaced and the tractor was not run after that, I would be thinking that they installed the disk wrong side forward. Which will mean another tractor split. Steve
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
