Posted by makin'hay on April 18, 2009 at 12:28:00 from (69.95.141.159):
I got the 300 back together. Recon. head-points, condenser, plugs,wires rebuilt carb, the works. Re-checked for TDC and proper firing order. I have good spark and compression and fuel to carb and she wont fire. After 7 or 8 revs, she backfires out carb. I didnt monkey with distributor and am wondering if that could be the problem. I noticed that the bolts that you back off so you can adj. the timing were loose. I did not turn dist. though. Is there a way to make sure dist. is properly set before it starts? Any help GREATLY appreciated. THANKS! I have left it the original 6vdc, + Grd. With new battery. Thanks
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
