Posted by JMOR on April 19, 2009 at 15:00:55 from (72.181.158.237):
In Reply to: Farmall H Carb Leaking posted by i bleed IH red on April 19, 2009 at 13:53:01:
Siphon? Much more likely a needle/seat/float problem. Gas will seep thru a hole that water won't. Suggest submerge float in gasoline or hold it under hot water and look for bubbles as heat expands warm air increasing pressure inside the float. Check for gasket & tight seat. Be sure float not dragging sides of bowl.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
