Re: Generator mounting
Posted by Janicholson on April 19, 2009 at 17:26:55 from (66.173.50.149):
In Reply to: Generator mounting posted by Mike CA on April 19, 2009 at 16:42:08:
There are only two particular concerns, one is that the belt is straight from pulley to pulley, the other is that it can be tightened without hitting the hood. There are two ways to put on the bracket, and the holes in the bracket can be made into slots (either milled out, or filed out with a rat tail file) There are only two screws holding on the reg. Make sure they are short to avoid shorting the inner workings , JimN
