Re: Farmall H Carb Leaking
Posted by GordoSD on April 20, 2009 at 05:30:32 from (66.115.200.140):
In Reply to: Farmall H Carb Leaking posted by Chris Armes on April 19, 2009 at 13:53:01:
Wheter the carb leaks or not you should get in the habit of closing valve at the sediment bowl every time you shut the tractor down. Thw last thing you need is a puddle of gasoline under your tractor.
Gordo
