Re: Sickle bar mower on Farmall 130?
Posted by mkirsch on April 21, 2009 at 04:58:22 from (64.80.108.55):
In Reply to: Sickle bar mower on Farmall 130? posted by Phil McPherson on April 20, 2009 at 22:23:21:
Your 130 actually didn't "come with" anything but the tractor itself. As they've said, a sickle bar mower was an optional implement, and there are several that fit the 130.
Is there a wooden stick, or the remnants of a wooden stick, with the mower? If so it is a model 22 mower.
The actual cutterbar assembly is identical between the Cub version and the A version. I have one of each, and laid them side-by-side to compare. The difference is in the drive mechanism.
The Cub drive unit is shorter, and has a large 3-spoke pulley at the rear. The A/100/130 drive unit is longer and has a solid 4-5" diameter pulley at the rear.
