I just replaced most everything you mentioned on my "49 M. The tapered bolts are still available from IH but expensive, about $24 each (x4). The rubber washers and the metal cups they set in are available also for about $4.50 per set (x8). I didn"t replace the ring, wasn"t worn too bad so I don"t know what it costs. With what I know now, I would recommend that you at least talk to a local machine shop about the bolts and ring. The shop could build up the bolts and turn them back down to the correct diameter and could also weld in and re-drill the holes in your worn ring. Might be cheaper.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
