Farmall H clutch shaft ring with tapered bolts
Posted by slydog on April 20, 2009 at 20:17:54 from (75.104.25.115):
Anybody know where I can get the clutch shaft ring and tapered bolts and rubber washers that connect the clutch shaft to the rear input shaft?
My bolts are worn and the ring has oblong holes.
