lift all pump maintenence after removing from tractor
Posted by slydog on April 21, 2009 at 19:00:22 from (75.104.25.115):
After I remove the lift all pump from the farmall H what maintenence procedures should I do to make sure it is up to par. The pump works ok now and doesn't seem to leak but after using it awhile and the oil gets warmed up it does seem like it is a bit weak. Is there something I can do to improve its perfomance beings I am going to have it out of the tractor?
Also I know I read on this forum about removing the pump with ready rod to make it easier. Can someone refresh my memory?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
