Re: Farmall H clutch shaft ring with tapered bolts
Posted by Bob Kerr on April 21, 2009 at 19:38:13 from (216.249.94.67):
In Reply to: Farmall H clutch shaft ring with tapered bolts posted by slydog on April 20, 2009 at 20:17:54:
Get new bolts and rubber rings at IH. As for the ring, I tried like everything to find a new one. I settled for a used one that wasn't worn too bad. Welding might be an option on that but I can tell you that ring is very much hardened and is shot peened to boot. Also if it isn't machined just right, you will get a wobble on the clutch shaft.
