Re: 140 won't charge/help John T
Posted by Janicholson on April 23, 2009 at 18:23:11 from (208.54.90.26):
In Reply to: 140 won't charge/help John T posted by Tom McArdle on April 23, 2009 at 17:36:42:
The originals were internal regulated alternators. With the appearance of an SI 10 connections. There is probably a fault in the exciter circuit. #2 terminal to the big terminal, #1 terminal to diode, or lamp, then to ignition. JimN
